Gas Guage does not read full when full?? Only reads 3/4 full?
Hey guys i when i messed with my cluster trying to get my integra cluster to fit better i messed up the gas gauge. When full it only reads 3/4 a tank there has to be a way to adjust this maybe on the back of the cluster??
Help
Spencer
Help
Spencer
be professional
Re: Gas Guage does not read full when full?? Only reads 3/4 full? (Spence)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spence »</TD></TR><TR><TD CLASS="quote">there has to be a way to adjust this maybe on the back of the cluster??</TD></TR></TABLE>
Well AFAIK, there isn't.
I'm assuming it was working properly before you messed with it? If so, you'll probably need a new fuel gauge. $43 at the dealer, or $37 + shipping here (look under "combination meter components").
The gauges are very fragile pieces - you have to be gentle with them.
Re: Gas Guage does not read full when full?? Only reads 3/4 full? (Targa250R)
the gauge still works it even goes a 1/4 way past Empty so its just out of alignment i guess
ok go fill up your tank and then take off the cover and move the needle to the full mark. and its all better.
Re: Gas Guage does not read full when full?? Only reads 3/4 full? (tcr03)
not sure i knew that it woudl be easy to fix i moved it when i filled the tank and it moved right back
have you ever taken the needles off, if so just take off the needle and put it back on full, but if i remember right the needles dont come off on the hondas. but its worth a try. if it doesnt work your still in the same boat.
sf@rx7
02-17-2006 07:42 PM
