compression ratios
compression ratios
I did a generic search but didn't find out what I was looking for. If you know the answer please share if you don't refrain friom using this statement "use the search key".
thanks in advance
OK, swapping a B16a2 head onto a B18cX shortblock will yield me what compression ratio. All parts OEM and nothing changed internally as far as pistons or cams.
If I went with a B18C5 Shortblock and 00+ ITR cams, how will that affect my c/r?
I'm trying to figure what aftermarket piston size I will need to get to attain my desired c/r.
thanks in advance
Re: compression ratios (00Red_SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR »</TD></TR><TR><TD CLASS="quote">http://www.c-speedracing.com/h...c.php</TD></TR></TABLE>
Is this right?
Block = B18c1/5 Bore = 81.00 Stroke = 87.20
Head = B16a/b - B18c5 Combustion = 42.70
Piston = p73-A0 (USDM B18C5) cc per piston = 3.64
Headgasket Thickness = OEM 3-layer thkness = .02900 Bore difference (mm)
[Gasket Bore - Cylinder Bore] I don't know
Piston-to-Deck Height = do I use b16 or b18
thanks again
Is this right?
thanks again
Re: compression ratios (civictildeath)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath »</TD></TR><TR><TD CLASS="quote">11.4 with p73-00 pistons jdm pistons
10.8 with p73-a0 pistons usdm pistons</TD></TR></TABLE>
so it will raise my comp then by swapping out the shortblock. will the cams affect it any?
Re: compression ratios (4-banging)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4-banging »</TD></TR><TR><TD CLASS="quote">
thanks again</TD></TR></TABLE>
use the b18 RE did it for you above
All Motor Mentor
1 Post
Is this right?
for cylinder bore, if you don't know if it's been bored out, just use "stock" setting for now. Piston to deck height refers to the block you are using which is the B18.
Is this right?
for cylinder bore, if you don't know if it's been bored out, just use "stock" setting for now. Piston to deck height refers to the block you are using which is the B18.</TD></TR></TABLE>
stock would be 0 then, correct?
thanks everyone for all your help
So, I'm looking at 10.8 c/r with a stock USDM ITR shortblock mated with a stock USDM B16A2 head. Cool
All Motor Mentor
1 Post
will the cams affect it any?</TD></TR></TABLE>
Cams will not affect your compression ratio.
EDIT- To all the perfectionest techies, I know cams have an effect on ultimate comp ratios but in this case we're measuring static comp ratio where they wouldn't be a factor.
All Motor Mentor
1 Post
Correct
Correct
Correct </TD></TR></TABLE>
thanks alot!!
thanks alot!!
stonet149
12
11-02-2008 09:29 PM
