Please someone go look at their headlight harness for me
can someone do me a favor and look at the wires that go to headlight connector on a 95 civic...... i replaced my connector because it was rotted out a long time ago, and at the same time installed a set of projectors, but was never able to get the high beams to work properly. now i have to fix it asap so it will pass inspection. there are three wires, all i need to know is the correct orientation. thanx.
Re: Please someone go look at their headlight harness for me (ManikOne)
I pulled the diagram out of the 1992 Service manual, and I looked at the harness out of my 94.... Looks to be the same, but I'm colorblind, so I'm literally working blind on the red/green wire and a couple of others.... but if your colors match up, then this should work.
Hope this helps.
Hope this helps.
Re: Please someone go look at their headlight harness for me (qat727)
that is the exact diagram that i have been looking all over for. what kind of service manual is that? that is what i need to get, i have two different ones now, with nothing that in depth as far as electrical connectors. thanks alot, ill try it out this afternoon and see it it works.
actually, I drew the diagram in paint after referring to the huge *** service manual that Honda put out for 1992 Civics and then looking at the wiring harness. The Honda manual doesn't go that in depth for most connectors, but it has been invaluable in figuring my car out. You can find them on eBay sometimes. There are different ones for each year. This one covers Hatches and Sedans from 92, both USDM and Canadian.
Frost7177
10-18-2009 08:30 PM
Dc2 Powered
09-23-2004 05:26 PM
