fule problem
Old 09-01-2005, 09:52 PM
kwil666's Avatar
Default fule problem
Im having a problem were sometimes when its really hot outside or my car has be sitting for a while ( like a week) it wont get any fuel. I have a fuel pressure gauge and it shows there is no pressure. And when I turn the key I don’t hear the pump start priming. I know its not the pump because I have replaced the stock pump with ether a gsr or a h22 in tank pump. After a while of trying to start it gets pressure and starts up.
Also sometimes when I driving say just leaving a light or just starting to go it bogs down like its going to stall. Its almost feels like im starting in the wrong gear.
On my fuel pressure gauge it says the pressure (when there is some) is at like almost 50 when im sitting still in the drive way and the car is idling.
Im not sure if these all have something to do with one another but that’s whats going on. I remember reading something about a (black box) for lack of a better name under the glove box that controls your fuel pump and all that stuff if that is bad could it cause all this? Whats the name of it also?
Thanks for your help I know its kind of hard to tell for what I wrote but if anybody can through me a bone that would be cool.
Keith
93 si b18c1
Old 09-02-2005, 03:44 PM
kwil666's Avatar
Default Re: fule problem (kwil666)
bump need some help here
Old 09-02-2005, 03:53 PM
civicboisi's Avatar
it sounds like it IS your fuel pump...did you replace the fuel filter also when you swapped out the pump? Filters rarely ever get changed and yours is probably long past due...
Old 09-02-2005, 06:35 PM
kwil666's Avatar
Default Re: fule problem (civicboisi)
i did change my pump its a gsr or h22 im not sure. the problem was there before and after the pump so i dont think thats it.
keith
Old 09-02-2005, 07:05 PM
civicboisi's Avatar
i mean the fuel FILTER...did you replace the filter? The pump and the filter is two different things...
Old 09-02-2005, 07:54 PM
kwil666's Avatar
i dont know actually thats a good question. but why would my pressure problem?
Old 09-02-2005, 07:59 PM
civic_driver's Avatar
because if the fuel filter is clogged no fuel can flow through... for no pressure at all, that filter probably has never been changed is clogged to the extreme..
or maybe your main relay is shot (you can take it out and check the solder connections and resolder them just to make sure they're in good condition)
Old 09-02-2005, 08:08 PM
suspendedHatch's Avatar
Default Re: (civic_driver)
He said his fuel pressure at idle is 50psi. Correct me if I'm wrong but that sounds ridiculously high. Too much fuel can cause the car to bog and stall. It should be obvious by your exhaust and your cat converter should be glowing hot and will burn out in a very short time.
Check your FPR with a vacuum pump.
Old 09-02-2005, 10:34 PM
kwil666's Avatar
Default Re: (suspendedHatch)
i know when i run open header at the track i was blowing black smoke but i dont see it on the street. i was thinking the main relay also (is that the black box thing under the glove box) maybe ill just replace the filter and then the main relay and see what that gives me. i need to pass smog and this isnt helping.
thanks for the help guys if there is any more out there ill take it.
keith
Old 09-03-2005, 03:11 AM
BoOstedEM1's Avatar
Default Re: (kwil666)
Change your filter, check your vaccums. and look at the condition of your main relay.. Then you should be fine.
Old 09-03-2005, 03:17 AM
I misread the post. I agree with suspended hatch. Check the fuel pressure regulator and check the line on the FPR for vacuum leaks.
It's most likely the FPR.
Old 09-03-2005, 10:56 AM
kwil666's Avatar
i have the stock FPR if thats what you mean. i havent got a adjustable one yet. where can i get a new main relay is that something i have to get from honda or a junk yard?
keith
Old 09-03-2005, 11:07 AM
DestructoEH's Avatar
This is the exact same problem I had with my car. My fuel filter was extremely dirty and it caused there to be more pressure in the lines than the fuel pump could take, in turn causing the fuel pump to burn out. Before I had done any of this, I had been having a problem with my car not getting any fuel and not wanting to crank when it was hot outside. It turns out it was the main relay (about 20 bucks in a junkyard). It's a small gray box with a red harness located right above your hood pop lever.
Just throwing my 2 cents out there.
Old 09-03-2005, 12:13 PM
postman's Avatar
b20bFourDoorCivicLX
08-04-2013 10:43 AM
egmatt93
11-12-2007 05:05 PM
Layziejoe775
04-12-2007 10:17 PM
RedRocketCRX
08-23-2004 01:50 PM
Andrew 825SM
11-17-2002 11:02 AM
Quick Reply: fule problem
