Oil leak
Oil leak
Sup guys,
I took out my camshafts the other day, to replace them with OEM ones. Now my problem is, oil is comming from behind the cam gears, behind the black cam gear cover, and eventually seeping down the block to the ground. It's a generally big leak, and replaced my valve cover gasket with a new one.
What else should I replace? Cam seals?
Thanks.
Thanks.
Re: Oil leak (CrX-To-Tha-Max-v2.0)
My guess would be that it is your cam seals, if you did not replace them or use some sort of silicone they usualy end up leaking.If you changed the valve cover gasket, and you didnt take the head off. that would be my guess.............
Re: Oil leak (JDMbiAtcH)
So it is the cam seals? This was one of my main guesses, I just wanted to make sure.
How much can I purchase them from honda for would be my next question.
Thanks.
Thanks.
patrickstar
19
02-16-2010 06:48 AM
vtec69
01-10-2003 05:31 PM
