My speedometer on my 93 civic ex keeps reading then disconnects back and forth
The speedometer wire is obviously loose somewhere, can anyone tell me where to check?
Re: My speedometer on my 93 civic ex keeps reading then disconnects back and forth (VTECsound)
It's your VSS(vehicle speed sensor).
The connection is on your transmission. If you look where your intake piping is then look down past the intake tube you will see a connector that goes directly into the transmission and has one bolt holding the actual gear to the tranny,
Clean the connector, if that doesn't work take out the VSS and clean it off then put it back in
civic4life8045
08-06-2011 04:41 AM
Vtec Civic 93
10
09-02-2010 08:52 PM
cc11386
12
10-31-2005 01:45 PM
