too tucked in?
too tucked in?
hi, im just wondering, i baught some tenzo R coilovers for my ek and noticed that my rear tires are tucked in, do you think this will mess up my tires or do i need to buy camberkits
Modified by EKizzle69 at 11:33 PM 9/1/2005
Modified by EKizzle69 at 11:34 PM 9/1/2005
Re: too tucked in? (EKizzle69)
need to complete the image. Once we see how tucked they are, we can tell you how much damage there will be. I think you should get a camber kit anyway.
-Shane
-Shane
Re: too tucked in? (nighttrain33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighttrain33 »</TD></TR><TR><TD CLASS="quote">What kind of car is that behind your car? Looks like an old school RX-7 or Supra.
-Shane</TD></TR></TABLE>
looks like a s-13?
looks like a s-13?
Re: too tucked in? (BoOstedEM1)
uhh iono my homie installd the coilovers for me, he didnt ask me by inches, he askd me like a # and i said iono so he juss made it 10 or something like that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKizzle69 »</TD></TR><TR><TD CLASS="quote">uhh iono my homie installd the coilovers for me, he didnt ask me by inches, he askd me like a # and i said iono so he juss made it 10 or something like that</TD></TR></TABLE>
In english please?
-Shane
In english please?
-Shane
i think he meant by the lines in the coilovers. i dont know how much my car is lowered by inches, but its 10 by the lines
Re: too tucked in? (ADVAN EG2)
Who lowers a car by lines on coilovers..Uhh well i was just saying that by 2.5 inches of lower you are starting to pull in the camber of the rear tires on a civic..and i think that on tegs the fronts start needing them instead of back..Any way you either need to raise it for now (unless you want to wear down your tires) or go out and buy a camber kit. Easy installation and Good product.
Location: South Bay, Torrance/Carson, CA, United States
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoOstedEM1 »</TD></TR><TR><TD CLASS="quote">Also what happened to your front rims..why the steelies..</TD></TR></TABLE>
I'm wondering the same exact thing.
That's the street racer look, black steelies up front and alloys in the rear. Ya know...gotta keep the drag tires on the car at all times!
Re: too tucked in? (Marauder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder »</TD></TR><TR><TD CLASS="quote">
That's the street racer look, black steelies up front and alloys in the rear. Ya know...gotta keep the drag tires on the car at all times! </TD></TR></TABLE>
oh fo sho haha straight up dragster right there
grammer nawzi
Re: (hoffman4684)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hoffman4684 »</TD></TR><TR><TD CLASS="quote">Get a camber kit; they are only like $110.00 anyway and are worth the $$.</TD></TR></TABLE>
Instead get 2 rims that will match the rear, EKizzle69 fo shizzle my nizzle bizzle bazzle blah, hate that ****. You're not snoop. . .
Re: (hoffman4684)
If it's for the rear, why spend so much? You can just shim the rears for 10 bucks in bolts and washers. As someone already mentioned, the more important thing here is to get an alignment done and make sure they zero out the toe and your tires will be fine even with the negative camber so long as you rotate the tires on a regular basis.
Re: (SoCal EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoCal EJ1 »</TD></TR><TR><TD CLASS="quote">If you're low enough to be tucking you'll need to get some camber kits unless you don't value the tread life of your tires...</TD></TR></TABLE>
If your running enough rear camber (-3 or -4 degrees) then it will wear tires faster, but still not as fast as toe will wear them. So if you value the tread life of your tires, get your toe zeroed out. If you don't believe me, search the suspension forum.
Re: (green00EX)
OK so both ways just get camber kit.. Alignment ..with toe zero. But either way if you dont youll be spending more money on tires. Uhh about the camber and toe thing.. I droped my EM1 a year ago 3+ inches and had so much camber that i wore true a set of toyo proxe z24s. In less than 3 months with zero toe..cause i listen to the forums..it doesnt cost much just around 110 for camber kit. Just get it and find those missing rims.
Re: (BoOstedEM1)
well...get an alignment CHECK first too see how far off the camber really is before you blow the 110 bucks or whatever it is...Then if it does need a camber kit, then buy them.
