knocking noises not CV joint. driving me nuts!
ok I am hearing an intermittent knock/s when I am turning a tight radius and sometimes going over bumps when going straight. even sometimes when accelerating.
it totally sounds like a busted CV but i had swapped in a new on and the noise was still there. definately coming from the driver side though audio checks outside the car.
I have checked:
all suspension bolts, engine mounts, subframe bolts, upper suspension bolts.
i have replaced the CV shaft, all the bushings in the LCA, lower BAll joint, Upper skunk 2 ball joint. still have the noise.
what's left???!!!
I'm gonna try to pull the upper A arm off today and see if those bushings are dead.
I'm at my wits end on this. does anyone else have a suggestion?
I have checked:
what's left???!!!
Re: knocking noises not CV joint. driving me nuts! (Turbo E)
I have the EXACT same problem. My axles are new and I replaced the upper and lower balljoints and the outter tie rod end. And it still knocks like when i'm doing a 3 point turn or pulling out of my driveway. i think its the inner tie rod.
ch0baca
08-06-2013 07:56 PM
FalkenSiR
08-05-2006 08:11 PM
