Problem with acceleration
Hey I have a 5 spd 93 honda civic 1.5 fuel injected. When starting the car up, everything is fine.. but when I step on the accelerator and rev the engine it sounds like its being choked out and the service engine light comes on. I checked for codes; there are none present. any ideas?
thanks
Modified by drummr6 at 5:28 PM 9/1/2005
thanks
Re: Problem with acceleration (fast88std)
could you refer me to a website with a picture showing the location of the throttle position sensor? or describe it to me
thanks
thanks
ok, yea i figured that out online, now how do i test it? i couldnt find it in my chiltons book... looked in index, emissions control, and where all other sensors are listed i didnt see it anywhere.
Re: Problem with acceleration (drummr6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drummr6 »</TD></TR><TR><TD CLASS="quote"> the service engine light comes on. I checked for codes; there are none present. any ideas?
are you sure you did it right?
Modified by ThatsMyEG at 4:43 PM 9/2/2005
Re: (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM »</TD></TR><TR><TD CLASS="quote">tps would usually throw a code, i'm betting its a clogged cat.</TD></TR></TABLE> Yeah It might be a clogged cat. If the subtrate broke inside the cat it will make your engine wanna die if you ry to accelerate. Do this jack up your car with the engine cooled off. And get to the cat. Hit the cat with your fist and see if you hear a noise that sounds like rocks. If it does then there you go.
Re: Problem with acceleration (ThatsMyEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThatsMyEG »</TD></TR><TR><TD CLASS="quote">
Modified by ThatsMyEG at 4:43 PM 9/2/2005</TD></TR></TABLE>
recheck the CEL (he says he's getting a check engine light... )
