B18B auto swap into EG
What is needed to do a B18B auto swap into a 94 Civic DX with the D15 auto engine? I would like to keep it automatic as its a daily. What ECU do I use? What about the wiring to the trans? I use the stock wiring harness, correct? What shifter cable do I use? Which combination of mounts would I use?
What brackets do I use to keep my A/C? Brackets for powersteering? Which radiator hoses?
Re: B18B auto swap into EG (slammed_gsr)
well to start off you would go about using the integra ECU.
The wiring I would try to use the civics as its direct clip on but if the car was automatic before then I'm guessing the proper connections will be there already for the b-series swap.
For mounts you will need 1994+ integra mounts.
I did somewhat of this swap but it was the b18a and did a bit of a write-up. Check out the link in my signature for more info.
Not too sure what you would do about the shifter linkage for the automatic shifter tho.
Ahknodd
05-18-2009 05:17 PM
