New b16 swap, some questions
I just got my obd 1 jdm b16a and its going into a 95 coupe. The distributor on the b16 is cracked, can I use my d15b7 distributor on the b16? Also all the hoses were cut on the engine, can I use most of the hoses from the d15?
NO and NO
I'd go OEM for a new dizzy and autozone or pepboys for your hoses. The dizzy will be the most expensive item.. the hoses are pocket change for even the brokest of asses
* B A N N E D *
Re: (MidwestSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidwestSiR »</TD></TR><TR><TD CLASS="quote">NO and NO
I'd go OEM for a new dizzy and autozone or pepboys for your hoses. The dizzy will be the most expensive item.. the hoses are pocket change for even the brokest of asses</TD></TR></TABLE>
my friend has a d16 dizzy on his b16
Re: (strictly.business)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicko360 »</TD></TR><TR><TD CLASS="quote">my friend has a d16 dizzy on his b16</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strictly.business »</TD></TR><TR><TD CLASS="quote">no he doesnt.</TD></TR></TABLE>
* B A N N E D *
the module is the same, the distributor itself is not.</TD></TR></TABLE>
ohhh, ok
ohhh, ok
Re: (AAAuthority138)
The shift linkage will work on your car, and distributor will not the distributor could run you anwhere up to 300 bucks. I have a OEM perfect cond. obd1 dizzy off of a b16 for sale $200... let me know.
1 Post
yes true... but, if you modify the distributor housing, D15/16 one WILL work w/B16(or any B-series engine) with a little bitta oil leak... this, I've done myself...
EG_LS
11-19-2007 03:04 PM
