Clutch Adjustment
Clutch Adjustment
I just installed a new master/slave cylinders. Before I changed them my clutch engaged close to the floor. Now, after changing them, the clutch engages higher up, with the pedal almost all the way out. Is there any way to adjust where it engages?
Re: Clutch Adjustment (B16B_coupe)
Yes. I ran a bottles worth of fluid through it after I got the air out just to make sure. I guess maybe its time to change the clutch. YUK
HRD PKR
Re: Clutch Adjustment (rickm)
possibly.. usally pedal high is for clutch wear. the further out the more its worn! but its not sopoes to let out at the floor.. is all the fluid clean still? in the res?
no air bubbles? where did u bleed it from? the slave?
All clean now. Poured in the res and bled out at the slave. I have a new clutch, I have just never done it before. Big Chicken!
tercelrcr
02-02-2013 06:25 AM
93SiHB
10-02-2005 10:00 AM
