CTR 5 Lug Conversion
Ok so I'm wanting to do a 5lug conversion on my '96 DX. I'm thinking about purchasing the CTR 5-Lug kit from Password. Its has the 32mm axles and I think that is the same size as what I currently have. I haven't changed the engine(yet).
Can I do the 5-lug swap without changing the engine first?
So far I know I need the following.
Complete 5-lug setup from CTR
99-00 Si MC & Booster
40/40 Pro Valve from Integra RS
Can I still retain my ABS when switching to 5-lug?
Re: CTR 5 Lug Conversion (EGRacersInc)
Your DX has ABS?
Stock D-series axles will work with the 5-lug. I suggest getting a 98-01 Integra 1" MC since it will directly bolt up to your stock BB and the brake lines will bolt into the MC without modification. If your DX is a hatchback, you don't need a prop valve, otherwise get one from an Si or 96-00 hatchback. The Integra RS prop valve will not work in your car.
Yes my DX has ABS . Will I be able to retain it or should I go ahead and pull it?
Also, thanks for the tip on the Integra MC. I wasn't sure if I needed both the BB/MC combo or just the MC.
My DX is a coupe so I'll be getting the prop valve from a 99-00 Si.
Thanks again guys. RSX Type-S Wheels here I come.
Uneekpinoysk8er
11-21-2004 06:54 PM
