Am I missing something?
Old 01-27-2007, 05:11 PM
shrekb18's Avatar
Default Am I missing something?
Are the bolts suppose to have a bunch of clearance in the bushing?
Old 01-27-2007, 05:16 PM
hondamark35's Avatar
Default Re: Am I missing something? (shrekb18)
i think the nut that goes on there has a collar on it, but i am not 100% sure about that... i do know it has a huge flange on it
Old 01-27-2007, 05:29 PM
shrekb18's Avatar
I ordered 2 new nuts from Honda and one new stud. Your right about the flange but there is no collar. The nut isn't even a locknut. It doesn't make mechanical sense? Why would there be such a loose fit? The rubber is there to allow movement right?
Old 01-27-2007, 05:30 PM
95civickid's Avatar
You honestly dont need that mount.... well the one on the driver side were the Ac would go ya that mount is pointless...
Old 01-27-2007, 05:31 PM
Luserkid's Avatar
Default Re: (shrekb18)
Is that the farthest you could push that mount back? Other then the way it is theres a special washer then the nut that goes to it.
Old 01-27-2007, 05:39 PM
shrekb18's Avatar
I know its not needed, Im just trying to figure out whats going one here. I have the washers
Honda calls out but they dont center the stud and the buching, its just a washer?
Old 01-27-2007, 05:56 PM
92ehatch's Avatar
Default Re: (95civickid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95civickid &raquo;</TD></TR><TR><TD CLASS="quote">You honestly dont need that mount.... well the one on the driver side were the Ac would go ya that mount is pointless...</TD></TR></TABLE>
that mount is not pointless. it keeps the motor from moving forward and back under acceleration.
trust me, mine was busted and my skunk 2 manifold was slamming my firewall. i got a new mount and some ES inserts and now it doesnt hit my firewall.
and to answer your question, yes they have clearance. that washer is not just a washer, it slides onto the ac bracket and will lock istelf into place (notice the hole isnt round its squared off
also, make sure you have the right mount on the right side. the mount pictured above is for the AC bracket. the other side looks like a V
Old 01-27-2007, 07:36 PM
happyabortion's Avatar
Default Re: (92ehatch)
those there are tourque mounts. without them and a strong launch you will break both your axles at once. i know this from first hand experience lol.
i remember on one of my swaps i ended up leaving it like that but its not suppose too. well ill double check on one of the ones i have laying around and see if i notice something missing
Old 01-28-2007, 03:31 PM
shrekb18's Avatar
Ok that might explain it, I dont have a washer with a square hole.
Old 01-28-2007, 04:41 PM
92ehatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shrekb18 &raquo;</TD></TR><TR><TD CLASS="quote">Ok that might explain it, I dont have a washer with a square hole. </TD></TR></TABLE>
its not 100% square...more like this (__)
but that slides over and locks into place and holds the mount solid.
Old 01-28-2007, 04:46 PM
shrekb18's Avatar
I'll look into this, Thanks
Old 01-28-2007, 04:57 PM
JSPECSIR's Avatar
me and my buddies always rap those studs with electrical tape all the way to the threads, until there a tight fit. hope this helps.
Old 01-28-2007, 05:39 PM
shrekb18's Avatar
So im not the only one!, Thats not a bad idea but doest answer the Q. Why is it this way to start with? Im thinking about making a sleeve but need to wait till I get the motor in to see where im at.
Old 01-29-2007, 09:04 AM
shrekb18's Avatar
Any other ideas?
TXaggie
06-05-2017 02:41 AM
TEGRA98GSR
04-21-2010 09:47 PM
pearl
18
07-29-2005 07:45 AM
jdmjay04
10
12-16-2004 10:56 AM
LostAndFound
05-11-2004 09:24 PM
Quick Reply: Am I missing something?
