reoving cruise control...plugging vacumme line?
removing cruise control...plugging vacumme line?
I read somewhere on ht that you need to plug a vaccume line after removing the cruise control...so what should i plug it with
Re: removing cruise control...plugging vacumme line? (excivicboy96)
Thanks guys...i have one other question, there is a hose connected to the cruise control unit that goes down into the fender area...what does that do? and can i just pull it out or plug it off. tia
Re: removing cruise control...plugging vacumme line? (B16b-EJ8)
what does it go to? im not sure cause my car had an electric cruise not a vaccum cruise.
Re: removing cruise control...plugging vacumme line? (JSPECSIR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSPECSIR »</TD></TR><TR><TD CLASS="quote">what does it go to? im not sure cause my car had an electric cruise not a vaccum cruise.</TD></TR></TABLE>
Well there is a vacume line going to a canister up by the firewall and then another larger hose that appears to dead end in the fender... I pretty much have these two figured out. not my question is weather or not i have to remove the actuator under the dash or if i can just disconnect the cable from the pedal? My car is a 99 ex with a b16b am i going to end up throwing a cell? this seems pretty straight forward so most likely i am over thinking this whole thing
yeah you can just take the cable off. you can prolly remove the canister by the firewall too.
jmccalip
06-15-2008 09:45 PM
xZeler8
11-10-2004 06:46 PM
