D16Y7 in EG, trying to keep power steering
My buddy just finished his D16Y7 swap into an EG. He's trying to keep his old power steering setup from the D15B. Apparently the brackets (D15B) would not bolt onto the head (D16Y7).
Is this just a matter of using the power steering pump bracket from the D16Y7 instead? Will the bracket(D16Y7) work with the pump(D15B)?
Just want to make sure before hitting the yard because right now it is too cold to be out. Don't feel like pulling the wrong part.
Re: D16Y7 in EG, trying to keep power steering (beelzebub)
i did the same swap what i did was just leave it undone and then just took it out . but you can also make ur own brakets and that would be the best bc even if u get a y7 pump its not goin to connect to the lines on the car...
HKSuperSi
10-14-2005 12:19 PM
bonbon
04-10-2004 02:19 PM
