IACV problem... need your help
Old 01-27-2007, 02:27 PM
footwork mastery
.Grimace's Avatar
Default IACV problem... need your help
hey my car idles at like 300-400 rpm when i start it and sometimes stalls out.......and when i hold my foot at 1500 rpm the motor revs back and forth from 1500-1700 rpm and i gotta press the gas pedal A LOT more to take it out of this "stuck" position, and i dont mean the pedal gets stuck i mean the "stuck" revving.......tried a new IACV still no luck. any ideas?
.Grimace is offline
Old 01-27-2007, 02:32 PM
93eg2james's Avatar
Default Re: IACV problem... need your help (Gremice)
happened to me. does your car hesitate during aceleration?
93eg2james is offline
Old 01-27-2007, 02:33 PM
footwork mastery
.Grimace's Avatar
Default Re: IACV problem... need your help (93eg2james)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93eg2james &raquo;</TD></TR><TR><TD CLASS="quote">happened to me. does your car hesitate during aceleration? </TD></TR></TABLE>
sure does. really bad around 6 thousand then goes up to redline perfect... just did my b16 swpa btw.
.Grimace is offline
Old 01-27-2007, 02:38 PM
93eg2james's Avatar
haha wow, 2 of a kind. Im in the same bind right now. I did a b20vtec build...
Im pretty sure its something electrical. I changed my cap and rotor, and that seemed to help quite a bit. My dizzy was pretty hagard so i went and got a new one. Unfortunatly the car is a non running state becuase i fried my ecu, so we'll see how it comes out then the new stuff gets here.
Check your plugs and wires.
Old 01-27-2007, 02:41 PM
footwork mastery
.Grimace's Avatar
new plugs and wires, new distributor, i'm throwing a code 14 (iacv). mine wouldn't even go past 4k until i got new plug wires. danm i hoped you had the answer.
.Grimace is offline
Old 01-27-2007, 02:43 PM
footwork mastery
.Grimace's Avatar
how'd you fry the ecu? if it had something to do with your problem i would like to avoid it
.Grimace is offline
Old 01-27-2007, 02:48 PM
93eg2james's Avatar
no when i did the swap i mixed up the EVAP solnoid and the IAT sensor plug... nothing you have to worry about.
have you tried cleaning the iacv? do you have a CEL?
Old 01-27-2007, 02:52 PM
footwork mastery
.Grimace's Avatar
tried a new iacv. throwing code 14...
.Grimace is offline
Old 01-27-2007, 02:54 PM
93eg2james's Avatar
code 14 is for a dirty iacv correct? you must have something stuck in one of the holes in the throttle body or in the IACV.
Old 01-27-2007, 02:58 PM
footwork mastery
.Grimace's Avatar
hrmm maybe. i am going to take off my throttle body to put on a new tb gasket so i will clean it up when it's off.
.Grimace is offline
Old 01-27-2007, 03:00 PM
93eg2james's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gremice &raquo;</TD></TR><TR><TD CLASS="quote">hrmm maybe. i am going to take off my throttle body to put on a new tb gasket so i will clean it up when it's off.</TD></TR></TABLE>
Old 01-27-2007, 03:50 PM
footwork mastery
.Grimace's Avatar
any other ideas? at my friends house about to weld up my exhaust (open header gets old real quick).
.Grimace is offline
Old 01-27-2007, 04:13 PM
arielmalespin's Avatar
hey the samething was happing in my b16 and just today i took the iacv off and spray brake cleaner in both holes and the car is working perfectly, so tried that maybe it might help
arielmalespin is offline
Old 01-27-2007, 04:16 PM
footwork mastery
.Grimace's Avatar
Default Re: IACV problem... need your help (arielmalespin)
i tried a new one but what the hell, why not, i'll give it a try.
i just want it to run right
.Grimace is offline
Old 01-27-2007, 04:58 PM
93eg2james's Avatar
oooooohhhhhhhh i think i found it!!!!!!!! heres out problem!!!!
https://honda-tech.com/zerothread?id=1846244
you have to move a pin on the ecu plug for the swap!!!!!!!
Old 01-27-2007, 09:51 PM
footwork mastery
.Grimace's Avatar
wow thank you for looking man. but i did switch the 3 wire to a 2 wire already. . i didn't get around to cleaning the tb or replacing the gasket. was too busy welding my exhaust to work. i'm glad it's quiet now.
.Grimace is offline
Old 01-28-2007, 11:17 AM
footwork mastery
.Grimace's Avatar
someone other then the 2 of us must of had this problem. anyone?
.Grimace is offline
Old 01-28-2007, 02:00 PM
93eg2james's Avatar
do you think maybe your timing could be off on the dizzy?
Old 01-28-2007, 02:03 PM
xXFiendxx's Avatar
Had a similar problem after swapping out my b16 a2 for a gsr bottom with b16 head . Turns out that my timing was off. Have you checked timing by chance?
xXFiendxx is offline
Old 01-28-2007, 02:06 PM
93eg2james's Avatar
Default Re: IACV problem... need your help (xXFiendxx)
haha ^^
Old 01-28-2007, 02:57 PM
footwork mastery
.Grimace's Avatar
yes, cam timing is perfect so is distributor timing. i am so lost
.Grimace is offline
Old 01-28-2007, 03:00 PM
93eg2james's Avatar
did you move that pin to the correct location?
did you get around to cleaning that stuff yet?
im pretty much possitive that its something blocking the holes for the iacv. take your intake tube off and take a look. something has got to be stuck in there
Old 01-28-2007, 03:27 PM
footwork mastery
.Grimace's Avatar
i already moved the pin. didn't get around to cleaning it don't get off work until 8 and i spent all last night hooking up my exhaust.
.Grimace is offline
Old 01-28-2007, 03:44 PM
93eg2james's Avatar
...burn it
Old 01-28-2007, 04:02 PM
footwork mastery
.Grimace's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93eg2james &raquo;</TD></TR><TR><TD CLASS="quote">...burn it
this is the best advice yet. but seriously i'll tell you how cleaning it goes hopefully tomorrow if i can do it in between classes.
.Grimace is offline
Quick Reply: IACV problem... need your help
  • Ask a Question
Question Title:
Description:
