car wont move
car wont move
so heres the story...
There has been a strange noise in my car. I thought it was the wheel bearings so i changed both sides and while i was at it i changed the axels. So i took the car out for a drive and still i hear the same noise. The noise gets even louder when im going above 25mph. So i jack the car up again to see it there is an loose bolts but everything was in place. So i drop the car and reversed it out of the garage and tried to take it out for another spin to see if there was any change but when i put the car in first gear and getting ready to go, I hear this noise that went "clunk". So after that clunk noise the car would no move. The car will not stall out even when i let go the clutch while in gear. So my question is what can be the problem?..blown clutch?..tranny fucked up? throw out bearing?.. by the way this is a b16 swap in to an eg with an ITR transmission. Please someone help me !!!
Re: car wont move (civicb16eg)
Do you still have clutch pressure? When you press your clutch does it pop back up? Or does it stay on the floor?
That would be the less likely factor that you blew out a clutch line.
I think it's more likely though that the clutch disk got screwy. I think it goes without saying to tell you to pull the tranny and open her up.
Re: car wont move (the blurr)
i agree with blurr.my cousin had this problem with his ef hatch.he went through 4 trannies with that carr all same thing.pin in the diff popped.
Re: car wont move (SCIVIC94)
blurr is right...i opened u the tranny and found out that the a piece of the diff broke..luckily i have a gsr tranny for backup so i guess the ITR tranny will be out until i decide on what to do...any suggestions?
i still have the same problem with the noise from the car. Could it be bad wheel bearings?...i picked up some used integra knuckles and im not sure whther or not the bearings are still good...what are some indications that i can find for bad bearings?..any other suggestions for this annoying noise from the car...
if it gets louder as you go faster its a bearing to check which side take your car out drive it until the noise happenes swing the wheel back and fouth when the car sway it puts load on each wheel bearing for example if you cut the wheel hard to the left and the noise gets worse then it is your right wheel bearing
the car makes the same noise when i turn to the left but when i turn to the right the noise stops...so does that mean my right side bearing is messed up?...
magicmike23
08-18-2007 05:28 PM
