Problem Starting JDM Type R
I cant get my JDM Type R motor to start on my EK9. This is the fourth engine on this car. Besides the stock, i had a USDM Type R and a LS motor that i swap myself and had no problem starting the motor. This is the same harness have used with all the prior motors and the JDM came off a working car. Starters been checked and battery's new. What is the problem?
Re: Problem Starting JDM Type R (sparkz_kzn)
is the cluster lighting up showing it has power? did you load test the battery? are you sure you have proper voltage? everything plugged in? is it cranking?
Re: Problem Starting JDM Type R (EndlessDc2)
Cluster has power, but nothing is cranking. The radio doesn't even stay on. The fuel pump is working cause i can smell fuel. The old battery was a die hard and had it tested at a shop. It wouldnt hold a charge so I exchanged it under warranty.
Re: Problem Starting JDM Type R (USDMej1)
it did start but wont stay on when i first did the swap. So I thought it just needed tuning. But now nothing happens
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMej1 »</TD></TR><TR><TD CLASS="quote">bad ground/s</TD></TR></TABLE>
