cluster gauge question
i have a 1994 civic Dx ... it has a cluster with no tach on it if i were to buy a 94 Si cluster .. will i have to change the wireing harness ... or can i just use the original ?
Re: cluster gauge question (HCJDM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HCJDM1 »</TD></TR><TR><TD CLASS="quote">tach and everything ... even if the one i dont have now has no tach ?
Plug and play.
Please search next time, this has been asked and answered many times. (yesterday?)
Plug and play.
Re: cluster gauge question (dr92cx)
ok...ill search next time ..im at work so i dont have time to search so i have to post and come back to the comp every 5-10 min ...
but next time ill search ... woo im getting a tach !!!!!!
be professional
All '92-95 clusters are plug-and-play interchangeable.
The correct tachometer cluster for a DX would be the LX 4dr closter, which has the proper tach redline (6500 RPM) for the D15B7 engine.
Re: cluster gauge question (Targa250R)
im putting a Z6 in ... what cluster would i need then ... o yeah and im keeping the d15b7 tranny .
if it has anytiing to do with it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HCJDM1 »</TD></TR><TR><TD CLASS="quote">im putting a Z6 in ... what cluster would i need then ... o yeah and im keeping the d15b7 tranny .
if it has anytiing to do with it </TD></TR></TABLE>
Tranny has nothing to do with your redline, that's strictly engine based.
If you're putting a Z6 in there get a 92-95 Si or EX cluster. They'll be plug and play and will have the correct redline.
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HCJDM1 »</TD></TR><TR><TD CLASS="quote">im putting a Z6 in ... what cluster would i need then</TD></TR></TABLE>
As Syndacate said, you'll want a cluster from an EX 2dr/4dr or Si 3dr for the Z6. They will have the correct 7200 RPM tach redline.
be professional
Re: cluster gauge question (bpkmrtoes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpkmrtoes »</TD></TR><TR><TD CLASS="quote">my 95 dx coupe redlined at 7.2.... it had a d15y7... is that normal?</TD></TR></TABLE>
A "D15Y7" doesn't exist.
A Civic DX was also never available with a factory tachometer, so obviously someone swapped in a cluster from an EX or Si.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">
A Civic DX was also never available with a factory tachometer, so obviously someone swapped in a cluster from an EX or Si.</TD></TR></TABLE>
I'm just telling what exactly was stamped on my block... it puzzled me too... but that's what it has.. of course it has an ex cluster.. i put it in there.. and i was suprized the redline was that high.
edit:: after doing some more searching i don't know how you can say it doesn't exist...
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpkmrtoes »</TD></TR><TR><TD CLASS="quote">I'm just telling what exactly was stamped on my block</TD></TR></TABLE>
No, it wasn't. If it was the stock engine, your block was stamped "D15B7."
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">of course it has an ex cluster.. i put it in there.. and i was suprized the redline was that high.</TD></TR></TABLE>
Are you dense? The redline of the EX/Si cluster is higher because it has a different engine. The correct DX/LX redline is 6500 RPM, as found on the LX tachometer for the D15B7 engine.
andre3wap
12-06-2013 01:29 PM
khhoa
07-11-2008 04:11 AM
