Does the starter solenoid go bad?
Old 01-26-2007, 10:15 AM
memorybox's Avatar
Default Does the starter solenoid go bad?
I just put a clutch in my b18b1 swapped civic. it took a few days due to rain, so now the car wont start without getting jumped off. But when its running the alternator works good, im reading 14+ volts at the alternator and battery, and i had my starter tested before the clutch swap and it was good
now when i try to crank it i just hear one click from the starter, and sometimes not even anything at all
even though the starter checked good could it have bad this time? or could it be something else?
if the starter is bad why would the car jump start? could it be no power getting to the starter?
Old 01-26-2007, 11:22 AM
Marauder's Avatar
Default Re: Does the starter solenoid go bad? (memorybox)
If it jump starts with cables connected to the battery, then it has to be either the battery or alternator. If it was the solenoid, then it wouldn't work either way.
Old 01-26-2007, 11:31 AM
memorybox's Avatar
Default Re: Does the starter solenoid go bad? (Marauder)
ok how do i find out what it is if they both test good?
Old 01-26-2007, 11:34 AM
turbociviccoupe's Avatar
is the tranny ground still on? just a wild guess. check your grounds
Old 01-26-2007, 01:26 PM
memorybox's Avatar
Default Re: Does the starter solenoid go bad? (turbociviccoupe)
it was the positive battery terminal connector, i hit it to nock it loose and the wire came out, so i tightned it down and it would crank fine thx
dvlsfan30
02-11-2009 09:45 AM
jorge59la
09-27-2007 07:24 PM
rafiq7
12-14-2004 07:46 AM
See Are X
03-06-2003 10:08 PM
Quick Reply: Does the starter solenoid go bad?
