reverse lights don't work.
Re: (dL_EG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dL_EG6 »</TD></TR><TR><TD CLASS="quote">Where is the reverse sensor?
It's not the VSS is it? I was messing with it trying to get it off a couple of days ago..</TD></TR></TABLE>
No, it's the other sensor sticking out of the tranny.
Re: (dL_EG6)
oh i know on the tranny there should be this black rubber thing. its on the very top if he doesn't have a pic i do i almost had the same probelm
Re: (tambara)
Yeah that took way too long, it's #6 in the diagram.
I couldn't find an actual transmission picture for some reason (or at least not a good quality one).
Hope that helps, got stuff 2 do, later.
EDIT:
I almost forgot, if you do change it out, make sure you replace that little washer there (12).
Re: (Br1anPham)
I'd say your sensor is busted.
Mine's weird. Sometimes it doesn't work but if I rev the motor they will usually start to work. My car is so ghetto.
Re: (Techy)
I say play with the sensor, take it out and do a simple wiring to a bulb, then if that works might want to consider running a new wire if you can't figure out where the break is. Lots of work for a reverse light, but if you want it that bad put in the work.
Re: (dad0c402)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dad0c402 »</TD></TR><TR><TD CLASS="quote">I say play with the sensor, take it out and do a simple wiring to a bulb, then if that works might want to consider running a new wire if you can't figure out where the break is. Lots of work for a reverse light, but if you want it that bad put in the work.</TD></TR></TABLE>
Or just get a new one and if that's not the problem put it back in the box and hold onto it. You can always sell it on the H-T market place as "used ONCE." for near what u paid for it .
LiLaZnKiD51o
13
08-10-2007 03:19 PM
