ls catch can
ls catch can
I was wondering if the ls motors suppose to come with a stock catch can?because i have a b16 head on now and they told to plug the bottom of the pcv valve[cus my ls didnt come with one]and they said it would be fine,but when i ranned it,it smoked down the whole way,i checked under the hood and there was oil all over the engine bay!what should i do!...thnx...
Re: ls catch can (GiceMob)
Not a single Honda comes with a catch can from the factory. They use a PCV valve that lets excess pressure gases to be burnt.
Where exactly is the source of the oil leak?
Re: ls catch can (DeadEnd9009)
well the pcv valve usually goes to the little black box in the back of block and mine doesnt have it so i put a bolt to block it off and my **** got fcked up,after i parked it though when it was sittin for like 3 days all of the remaining oil leaked out...
you need to hook up the pcv. if you running a hose straight from the intake manifold to the block, you gonna suck in a lot of oli
cute little bastard
Your friends are lying to you. LS's def came with a breather box
You can either put the buy a breather box and put it back on or go the catch can route
https://honda-tech.com/zerothread?id=1199935
Live*JDM
14
05-16-2006 09:30 AM
