how to remove the steering wheel hub?
how do i remove the steering wheel hub to remove the wiper switches and the signal. I want to remove the whole peice and install a new one. I took off the steering wheel but it looks like the hub which u attach the steering wheel to it like mounted on there. the plastic piece is just one whole peice wiht the srs and everyting that im tryin to install. Can someone help me? Thanks
HT White Ops
If you have a stock steering wheel, you have already removed the hub. That part that's sticking through the SRS reel is the spindle on the column.
To take the SRS reel off, there are only three screws holding it to the combination switch. Remove that, and reset it's position. Turn it one way till it stops, and then turn it 2 1/2 times. Tape it so it won't move.
b18_crx
06-19-2006 09:19 AM
W O T
09-22-2005 09:05 PM
