Replacing axle
Replacing axle
93 Honda Civic, I am replacing the axles on the Civic. I had a question on the 32mm nut. IT is righty tighty lefty loosee for both ends. Right?
Also Do I need to replace the seals, the transmission side is dry but has a v littlle seepage. If YES, is it simple like pulling the seal and replacing it? Any tools needed?
Thanks
Thanks
Guest
Posts: n/a
Re: Replacing axle (dan_g)
seal just pops out, yea always replace it.. cost what 4bucks each ?
axle, yup standard for each side, what i do is just get a couple sprays on pb for a day before you do it, hit it every couple hours.. then put the break bar on so its even with the car on the door side and stand on the bar, use your bodyweight and bounce.
always worked for me
