What to do while motor is out?
So I pulled my B16A out today so I can paint my engine bay and I was wondering, since it's out what can I do to it? I know I can do timing belt and water pump. What else? I'm talking about what kind of maintenance I can do to the motor that will be harder when its in the car.
Modified by SiYouLater at 1:51 PM 2/21/2007
cute little bastard
Re: What to do while motor is out? (SiYouLater)
Wire tuck?
Are you talking about just appearance stuff?
I mean theres a shitload you can do to the motor while its out. Depending on how much $$$ you got.
are you talking about the engine or the bay? I think you should shave the bay and paint it some ballin *** pink color and then a wire tuck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiYouLater »</TD></TR><TR><TD CLASS="quote">So I pulled my B16A out today so I can paint my engine bay and I was wondering, since it's out what can I do to it? I know I can do timing belt and water pump. What else?</TD></TR></TABLE>
So why is the motor out? Since the motor is out you might as well...
REPLACE
- Oil pump/oil pickup
- Timing belt/water pump
- Rear main seal
- Crank seal
So later on down the road you won't be mad when your seals start to leak. I'm sure there is more you can do, but these are things that should be taken into consideration.
REPLACE
- Rear main seal
- Crank seal
you can take picutres of yourself sitting in the engine bay of your car.....doing goofy things...that's what my friends and i did when his engine was out....
Re: What to do while motor is out? (platinumx6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinumx6 »</TD></TR><TR><TD CLASS="quote">are you talking about the engine or the bay? I think you should shave the bay and paint it some ballin *** pink color and then a wire tuck.
that right there should about cover it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiYouLater »</TD></TR><TR><TD CLASS="quote">So I pulled my B16A out today so I can paint my engine bay and I was wondering, since it's out what can I do to it? I know I can do timing belt and water pump. What else? I'm talking about what kind of maintenance I can do to the motor that will be harder when its in the car.
Modified by SiYouLater at 1:51 PM 2/21/2007</TD></TR></TABLE>
polyurethane engine mounts??
Re: What to do while motor is out? (Agent337)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Agent337 »</TD></TR><TR><TD CLASS="quote">
polyurethane engine mounts?? </TD></TR></TABLE>
Done.
Done.
* B A N N E D *
lol classic honda tech, what can i do maintence wise to my motor while its out, people start listing pit the block, valve cover, shave, engine bay lmao gawd
front and rear valve seals guy? what the hell, valve seals (there are 16 of em) are acutally needed to be pressed in and out of the head
you tlking about crank seals? rear main, and front crank seal?
DOHCgarage919
09-03-2007 05:31 AM
