Max power on 93 Q
Max power on 93 Q
Im having a little arguement with some friends right now.. Im building a turbo d16 and i have learned 325-350 to the ground is MAX for pump gas(93 here). Thats perfectly OK number for me! But can say a b18-t go for more than 350 on pump?
I read that the max power you can run on a certain octane is due to detonation but im not sure how it all plays out.
Thanks for the help.
Re: Max power on 93 Q (platinumx6)
The guys around here always push 93 octane to ~400whp on built b-series vtec motors, then after that they need to really strain the turbo for a little extra hp. By straining, I mean +5psi for +15whp - its the timing retard required that really gets it after that.
I also wouldn't expect a 1.8L dohc to have a higher power ceiling for pump gas than a d16. The d16 has a smaller diameter bore and faster piston speed [in relation to its stroke size]. Because of that, it will spend less time with the mixture at max compression and burns to the sleeves quicker, which both naturally give it less time to cause preignition.
Re: Max power on 93 Q (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile »</TD></TR><TR><TD CLASS="quote">The guys around here always push 93 octane to ~400whp on built b-series vtec motors, then after that they need to really strain the turbo for a little extra hp. By straining, I mean +5psi for +15whp - its the timing retard required that really gets it after that.
I also wouldn't expect a 1.8L dohc to have a higher power ceiling for pump gas than a d16. The d16 has a smaller diameter bore and faster piston speed [in relation to its stroke size]. Because of that, it will spend less time with the mixture at max compression and burns to the sleeves quicker, which both naturally give it less time to cause preignition.</TD></TR></TABLE>
this is what i was looking to hear. thank you.
Re: Max power on 93 Q (urnotfast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urnotfast »</TD></TR><TR><TD CLASS="quote">my friend has a daily driven b18 making 420 on 93 octane its a 1.9 lsvtec.</TD></TR></TABLE>
MikeSarr_GSR
19
10-14-2006 11:53 PM
