popping sound
popping sound
ok i have a 92 hb si and when i come to a hard stop or go over a bumb hard there is a popping sound coming from the front wheels, i was thinking it was the bushings gone bad...but if any one knows what this is please let me know.thanks
Re: (biggishjay)
when mine did the same thing it turned out to be the uca, changing the bolt helped but putting another one in from the junkyard got rid of it. I say check all the bolts and joints for anything loose, I discovered mine when working in that area of the car, grabbed the uca with my hand to pull and felt it pop. It was the only thing I didn't check, so check everything. From bottom up if it helps you keep track.
Re: (dad0c402)
Is it as you are stopping or after you stop and you begin moving again...if so aside from what others have posted make sure you're calipers are all ok and no corroded because the brakes may be seizing on the rotors due to that or over heating.
HT White Ops
I had a CLUNK that happened on the left side when I would decelerate to a stop, and accelerate from a stop. Turns out that my front LCA was bent. I replaced it, and it hasn't happened since.
Nizzy
Welding / Fabrication
08-16-2004 11:55 PM
Ricey McRicerton
48
07-24-2004 07:50 PM
