top dead center?
top dead center?
last code to clear and no cel.. im getting code 8 which is for a top dead center
sensor.. where is it located and what do i have to get to fix it?
also will a gsr driver side engine mount fit on a b16?
Well....code 10 is for the IAT, not tdc
http://www.hstuners.com/forums...23007
Mounts are more 'chassis-specific' than engine-specific.
If this is in an eg, then yes, the gsr mount will work
Re: (pdiggitydogg)
sweet man thanks for the mount info
ok sry about the cel code its an 8 i just fixed the iat
gonna ninja edit that haha
Alright-
The TDC sensor is in the distributor
you may have skipped a tooth on the timing belt - is it older?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC »</TD></TR><TR><TD CLASS="quote">put the engine on TDC on teh cam gear.. alignt it with the marks.//// and the UP looking straight... take the dist cap off and whenever the rotor its pointing , thats where the number 1 cable should be put and then follow firing ordder counterclockwise!!!!!!...</TD></TR></TABLE>
japspecjohn
05-01-2006 08:51 AM
