need some info on wiring a b16 into a 96 ek coup
i'm building a ls\vtec for my 96 ex and need to know a fewthings before i go any further. i'm going to run a b18b block with a b16 head and my first question is i'm already converted to obd1 with a shunk2 p28, so should i run an obd1 or obd2 head to work with that ecm? the other question is will the b16 plug into my stock d-series harness or is there a conversion harness that i might need? any help i can get would be great.
1 Post
Re: (HONDA300)
if you're using OBD2 wiring harness off a VTEC engine(D16y8), you won't have any problems. If using OBD2 non-VTEC wiring harness, you have to add VTEC and VTEC pressure plugs. Also, you don't necessarily need to use OBD2 head.. you can use ANY DOHC VTEC head and ANY B-series block(except for the old Prelude block) for the conversion.
just make sure you have matching wire harness and distributor.
1 Post
Re: (HONDA300)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDA300 »</TD></TR><TR><TD CLASS="quote">it's a y8 but i was just wandering if the b16 dizzy plugs will they plug right in</TD></TR></TABLE>
what's it off of? OBD1 or 2?
Here to make it simple. Use the car harness. OBD2a EX Harness. Use OBD2a/b VTEC head. Everything will connect no problems. Have a OBD2a to OBD1 Jumper and Plug your P28 and your good to go.
danxdan
06-09-2005 04:46 PM
FritzInTN
07-10-2004 09:45 AM
