i think this is a stupid questin
this is probably a stupid question but ive asked a couple of people, what exactly does a AEM adjustible cam gear do? i can find an awnswer for this question
Re: i think this is a stupid questin (iwanttogofast)
if you don't know what it does yet, it's prob best you don't mess with it till you do research. no offense but have you used the search function yet? I'm fairly new and I think it's in red font for a reason.
An adjustable cam gear on a single cam will allow you to "adjust" the powerband for better low end (advancing the valve timing) or more top end (retarding). On a dual cam you can gain power, they are best tuned on a dyno until the optimum setup is found. They are usually aluminum, which also lowers reciprocating mass.
Unceasing Measure
Re: (Guam_CiviC619)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Guam_CiviC619 »</TD></TR><TR><TD CLASS="quote">An adjustable cam gear on a single cam will allow you to "adjust" the powerband for better low end (advancing the valve timing) or more top end (retarding). On a dual cam you can gain power, they are best tuned on a dyno until the optimum setup is found. They are usually aluminum, which also lowers reciprocating mass.</TD></TR></TABLE>
Quick addition: This is how one goes about adjusting the mechanical timing of an engine. The ignition timing has nothing to do with this, so don't get the two confused
Also, SOHC or DOHC, they should all be tuned on a dyno for the best results.
