engine swap ?
engine swap ?
alright im sure this topic has been posted on over n over again but i cant seem find wat i need 2 know, ABOUT how much would it cost for a full b16 engine swap with everything in 2 a 96 civic, i heard it was kinda troublesome...
Re: engine swap ? (96 hatch)
from hmotorsonline.com
http://hmotorsonline.com/shop/...30005
B16A 92-95 (SiR-II) Complete Change Over
Price: $ 2250.00 Plus shipping and handling
Availability: In stock and ready to go
- Motor
- Hydraulic Tranny (S21, Y21)
- ECU (P30)
- Axles with Half Shaft
- Shift Linkage
- Stock Motor Mounts *
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Comes With All Sensors Needed
- LSD Tranny (Optional +$300)
plus misc items that you should change to make sure everything runs good. plus obd2-obd1 harness. more if you just get an obd2 swap.
- Motor
- ECU (P30)
- Shift Linkage
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
Re: engine swap ? (PreFerio)
depends on what you want to do. jdm swaps generally have low miles. can never be certain though.
i ended up going with a swap since im in cali, and i wanted everything to be legal. so it was either a greddy kit, or swap. i went with the swap.
Re: engine swap ?
iv thought about it, it makes sense but i wouldnt know how 2 get started, where could i find a list of things i would have to buy?
since you are in cali man, i would personally try to make something legit and legal to fall back on, whether it be a greddy kit carb sticker, or a bar'ed engine swap...that way if you get in to issues, you have some kind of backup. otherwise, you swap in a 92 b16 into your 96 civic, get pulled over, popped hood, and you, my friend, are fvcked.
The Alchemist...
05-02-2005 03:49 PM
