E85. What would it take??
Alright, the question is simple, what would it take for our D/B/H/K engines to run on E85 ethenol gas?? Dosnt E85 allow you to raise compression, thus increase power???
Unceasing Measure
Re: E85. What would it take?? (turnsignalandy)
E85 is higher octane than regular gasoline, so it resists detonation better just like any high-octane fuel. That said, you could run more boost, more compression and more timing to make more power on E85. Search for E85 in the forced induction forum for more info, as people have already done this.
Re: E85. What would it take?? (dr92cx)
Quote, originally posted by hondachris1994 »
buy a helms manual it will show u step by step
Quote, originally posted by uo959 »
what do they look like??
Quote, originally posted by usdmej1 »
looks like a fuucking book.
Made me laugh.
Made me laugh.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr92cx »</TD></TR><TR><TD CLASS="quote">You're going to sacrifice quite a bit of fuel economy though.</TD></TR></TABLE>
Re: E85. What would it take?? (**DOHC HaTcH**)
so this would be something for racing purposes more then DD purposes. What kind of power could you make, could you make over 220whp on a SOHC N/A?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turnsignalandy »</TD></TR><TR><TD CLASS="quote">so this would be something for racing purposes more then DD purposes. What kind of power could you make, could you make over 220whp on a SOHC N/A?</TD></TR></TABLE>
yep basically...what you could do instead of using E85 is pump 91 and use the fuel/octane boosters, some say they work haven't tried it myself though.
Re: E85. What would it take?? (bmoua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmoua »</TD></TR><TR><TD CLASS="quote">
yep basically...what you could do instead of using E85 is pump 91 and use the fuel/octane boosters, some say they work haven't tried it myself though. </TD></TR></TABLE>
no...it would take a ton of octane booster to take 91 all the way to what 105(octane of e85), that is not possible.
https://honda-tech.com/zerothread?id=1812349
https://honda-tech.com/zerothread?id=1844228
https://honda-tech.com/zerothread?id=1743000
https://honda-tech.com/zerothread?id=1611704
And about 40 other threads on the same topic.
Please search
Using e85 in our cars is more performance oriented, since it has a much higher octane and therefore is harder to result in detonation - turbo applications
You could use it, if you wanted to be "greener" but you will lose fuel economy, since it takes more fuel to use it in our engines - larger injectors, larger pump, higher pressure, and some sort of A/F computer (ie- SAFC)
Please search
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turnsignalandy »</TD></TR><TR><TD CLASS="quote">Quote, originally posted by hondachris1994 »
Made me laugh. </TD></TR></TABLE>
hey that was me before i was banned.
ejgsr.
ejgsr.
illmatic520
01-23-2008 07:21 PM
bboyoxygen
07-25-2006 08:51 AM
