questions
questions
so i was wondering (don't get mad) about how to change the anti-freeze meaning how to drain it. the process. and when changing ur brakes do u have to bleed out the fluid? and is it cheaper to do it urself or just take it out to a shop? thanx in advance
Re: questions (yesSiReK)
You don't have to bleed the brakes, you can replace the pads yourself and save a lot of $$.
To drain the anti-freeze just open that screw (whatever it is called) at the bottom of the radiator.
Re: questions (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">You don't have to bleed the brakes, you can replace the pads yourself and save a lot of $$.
To drain the anti-freeze just open that screw (whatever it is called) at the bottom of the radiator. </TD></TR></TABLE>
wat about the rotors? same thing? just replace nothing else?
and i heard with the anti freeze u need to like heat the car up until the thermostat opens and then u drain it or is all that really not needed?
I dunno if you mean just bleeding it but heres a write up on how to flush it https://honda-tech.com/zerothread?id=1424191
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yesSiReK »</TD></TR><TR><TD CLASS="quote">
and i heard with the anti freeze u need to like heat the car up until the thermostat opens and then u drain it or is all that really not needed?</TD></TR></TABLE>
Rotors are easy to replace too, they just require a little more work. Check out the FAQ thread at the top of this forum, they have "How-To's" on lots of stuff.
Why are you draining your anti-freeze?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rev2Eight_EM1 »</TD></TR><TR><TD CLASS="quote">I dunno if you mean just bleeding it but heres a write up on how to flush it https://honda-tech.com/zerothread?id=1424191</TD></TR></TABLE>
koo thanx yo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">Rotors are easy to replace too, they just require a little more work. Check out the FAQ thread at the top of this forum, they have "How-To's" on lots of stuff.
Why are you draining your anti-freeze?</TD></TR></TABLE>
well i don't know if i need to but my gf's car is runnin' on water... so i thought i might need to flush that out and then put in new anti freeze
koo thanx yo
hatchinprogress
08-31-2006 10:01 PM
