need help with my speed sensor, reverse, and coolant
New User
has anyone had problems w/ their speed sensor and reverse light??? i've changed out the speed sensor...thought it was the wire harness changed that too, still not working...also thermostat won't open w/ motor running hot, but tested w/ boiling water it opens...any suggestions???
Re: need help with my speed sensor, reverse, and coolant (rtrsl)
for less than 10$ change the thermostat, and as for the no speedo, change your cluster
New User
Re: need help with my speed sensor, reverse, and coolant (blackfoot)
thanks, come to find out it wasn't the thermostat but radiator cap. solved that issue but still having problems with reverse light not coming on in reverse and no speedo. checked all possible fuses, everyone ok.
