Valves?
Valves?
I Have a b16a2 with pro-series cams which valves should i use? (i was thinking of high comp standard size.) but my homie said to go with oem because they are lighter? lmk what u guys think.
Re: Valves? (mr.compton)
go with oem. no point in making your valvetrain heavier than it has to be. mill the head a lil bit if you want a lil more compression and use a thinner headgasket.
WHERE ARE YOPU GETTING THE IDEA THAT THE AFTERMARKET VALVES ARE HEAVIER? THE OMNI POWER VALVE TRAIN ARE LIGHTER THAN STOCK! AS IN MOST AFTERMARKET PARTS ARE STRONGER AND LIGHTER!!! AND HEAVYER VALVE TRAIN WONT MAKE A DIFFERENCE!
Darth ModerVader
Re: Valves? (TWINTECH93JDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TWINTECH93JDM »</TD></TR><TR><TD CLASS="quote">O AND BY THE WAY THICKER HEAD GASKET MORE COMPRESSION!!!!!!!!!!!!!!</TD></TR></TABLE>
By the way, that's entirely incorrect.
And stop typing in all caps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TWINTECH93JDM »</TD></TR><TR><TD CLASS="quote">WHERE ARE YOPU GETTING THE IDEA THAT THE AFTERMARKET VALVES ARE HEAVIER? THE OMNI POWER VALVE TRAIN ARE LIGHTER THAN STOCK! AS IN MOST AFTERMARKET PARTS ARE STRONGER AND LIGHTER!!! AND HEAVYER VALVE TRAIN WONT MAKE A DIFFERENCE!</TD></TR></TABLE>
your incorrect. all flat faced valves require more material to make the flat face therefore adding weight to the valve and just to be clear oem valves are not heavy and when compared to a flat faced valve the oem valves ARE lighter.
where do u get your info from? calm down noob u have alot to learn. you should learn alil before you try calling people out. a THINNER headgasket = higher compression.
xDicktonesx
12
03-08-2006 04:29 PM
