b20 vteck cams?
b20 vteck cams?
What are the most agressive cams I can use on my head. Stock block not milled with stock gsr head. 180 compression across..
1 Post
Re: b20 vteck cams? (moods3)
well if you are talking after market I hear the skunk2 got good ones for this.
if you are going OEM ITR cams IMO.
don't forget to upgrade you oi pump and your fuel pump and water pump.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moods3 »</TD></TR><TR><TD CLASS="quote">What are the most agressive cams I can use on my head. Stock block not milled with stock gsr head. 180 compression across..</TD></TR></TABLE>how about no cams since the stock cams will not let the valves clear the pistons. the piston will do some hammering on the valves like this hammer hitting your head
I,m running 98-00 ctr rite now. No smacking on the pistons yet that i know of.. but want better cams
vteck huh? Never seen it spelled that way before.
Look into Skunk2.com, and read about their various stages. You'll see which ones require a valvetrain upgrade.
NOSED_CRX_VTEC
11-29-2006 09:53 PM
