clicking noise after new clutch?
Old 11-05-2007, 04:00 PM
frostwhite93cx's Avatar
Default clicking noise after new clutch?
Just replaced stock clutch on 93 cx. There seems to be a clicking noise more often than not. Loud in 1st,2nd, then gets quieter in later gears. Do i need to adjust the clutch?
Old 11-07-2007, 11:25 AM
Default Re: clicking noise after new clutch? (frostwhite93cx)
does anyone know what the problem might be?
Old 11-07-2007, 04:12 PM
RIZOBIZERT's Avatar
You replaced the stock clutch with another stock clutch, or an aftermarket? Did you put in a new throw out bearing and pilot bearing? How about the fluid in the trans? Did you change it or check it? A little more info and I'll do my best to help. I've done a dozen or so clutches from an 87 Nissan Stanza to a 2006 RSX-S. Just fill us in on everything that happened. Oh, have you tried driving on jack stands or a lift to make sure it's the trans making the noise and not something with a half shaft rubbing?
Old 11-07-2007, 04:25 PM
instrument's Avatar
hope you resurfaced your flywheel.
people describe noises differently.
might be chatter.
may be an axle going out.
who knows.
Old 11-08-2007, 09:48 AM
Default Re: (instrument)
I'll have to check on the half shafts for sure, it does sound more like something is rubbing rather than coming from inside the tranny.
Old 11-09-2007, 05:09 PM
Default Re: (frostwhite93cx)
I checked with the shop and I have a loose axel. Could a loose axel make a clicking noise?
Nick Kozeski
09-02-2015 02:18 PM
godruler
12
09-03-2006 12:54 PM
integra15
07-27-2006 10:36 AM
garados
02-03-2003 11:08 AM
Buckshot
11-06-2002 05:29 PM
Quick Reply: clicking noise after new clutch?
