Radiator W/ no Fan
Emergency Help - Radiator W/ no Fan
I just got my car running today. is it safe to run my car with the stock eg rad. w/o a fan?
also, I have an integra rad with both fans on there, where one would be the best fit for the eg rad?
Thanks
btw, I have a b18b
Modified by bimmeracer at 6:38 PM 11/5/2007
Thanks
btw, I have a b18b
Re: Emergency Help - Radiator W/ no Fan (bimmeracer)
I ran my car for half the summer with no fan and it never overheated, but im up in ohio... only would heat up a little fi it sat running for a bit.
1 Post
if i was you i would not run that car with out a fan!!! due to the fact you in florida!! im in new york and my fan was not turning on!! car was getting hot!! you going to wrap your head or crack a sleeve!! be careful!! i learned the ahrd way overheating will kill a honda quick
Re: (holset b18c)
It doesn't matter worth of dick, as long as you're not idling for awhile.
Fan = move air across radiator when you're not moving. So that means just don't leave your car unattended to idle and keep ur eye on the temp gauge.
Thanks guys, but I would prefer to play it safe and use one of my fans from my teg rad.
For Bimmers we have something called fan delete in which we remove our fan and add water wetter and a lower temp thermostat. Is there anything similar for Hondas?
Re: (bimmeracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bimmeracer »</TD></TR><TR><TD CLASS="quote">Thanks guys, but I would prefer to play it safe and use one of my fans from my teg rad.
For Bimmers we have something called fan delete in which we remove our fan and add water wetter and a lower temp thermostat. Is there anything similar for Hondas?</TD></TR></TABLE>
you could probably do this... but you'll probably elevate your "normal" running water temp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">It doesn't matter worth of dick, as long as you're not idling for awhile.
Fan = move air across radiator when you're not moving. So that means just don't leave your car unattended to idle and keep ur eye on the temp gauge.</TD></TR></TABLE>
this is true... you can probably run without a fan unless you're turbo'd (esp with a turbo timer).
Re: (pgpunkguy)
like guy above me said throw fan on there if worried or go buy a slim fan for $50...
i have a b18c1 and i live in Texas, ran my car with no fan all summer long even on like 100 degree or hotter days... just don't let it sit too long... i had to turn the heater on if i was stuck in really bad traffic but as long as i was moving most of the time it was fine...
GRANT!
10-27-2009 03:37 PM
