D16Y8 swap to B16
D16Y8 swap to B16
I need some advice....I have a d16y8 in my 97 ex, I want more power and have read about the B16 or K20 swap but I am new to the Honda scene and have never attempted a swap like this before. I was told and have read different forums about this swap but I am still unsure about everything that I may need and an approximate cost of this project. In order to complete this swap including a/c and power steering what will I need? Will I need to swap the tranny as well?
Re: D16Y8 swap to B16
Just got done swapping my EK 1998 LX with a b16a and I'm loving it,
The b16a would be a PnP in your civic ex if its manual you can use your old harness and keep the mounts. Only thing you need is complete the b16a(tranny axles headers etc..)
For a k20 you need like custom made mounts for hassport maybe a little shaving to the engine bay
You can also go B18C1 with the y8 harness. The mounts should be the same (for the most part) except for the rear t-bracket and front lower torque mounts. You will need a s80 or y80 B-series Hydraulic Clutch Transmission and an ECU. If you want a stock running swap, you can keep OBDII with a 96-98 ECU from a Integra GSR for the B18C1 or 96-97 Del Sol VTEC for B16. Or a B18C5 with a Type R ECU but this may hard to find.
Expect about $2500+ for a B16 or B18 Swap.
K swap is a whole different animal, with about 2-3x the cost. But, then you do end up with a K.
Ok well I am going to start looking for parts. Think I will attempt the B18C1 swap, anyone with parts for sale just inbox me and let me know. Thanks
