Crower & Supertech
Crower & Supertech
Hi there,,,
does anybody knows if I can run Crower Chromoly retainers (part # 87093) with Supertech Dual Valve Springs ( SPR-H1002D )
Reason I ask is because I need them for a DD that will be running Skunk2 Tuner 2, and I donīt want use the Titanium ones on this build up.
I searched and found that Supertech ### will handle the max lift of 12.4mm, but I want to use Chromoly retainers for durability...
Thanks
Thanks
Re: Crower & Supertech
I did see Supertech makes them as well.... the reason I went ahead and search for an alternative was because I did not find the specs of the supertech steel retainers. On the other hand, I found all the info about the Crower ones...
Are you happy with your current set up ?
What cams are you running?
precisionelite
05-01-2006 12:39 PM
