96 Honda civic tachometer questions
I am installing a tachometer on my 1996 Honda Civic EX and on the tach I have 5 wires, a yellow 12v Constant Source (un-switched), a red 12v Ignition source (switched), a black ground, an orange 12v Switched Headlamp Source, and a green tach source wire.
Now from this, I understand the yellow is the main power and it goes into the fuse panel (I used an add-a-circuit). The Green goes on the back of my cluster to the blue/silver tach wire. The black is grounded under the dash. But where am I supposed to install the red wire? Same with the orange one.
The tachometer I am installing is this one from Glowshift:
http://www.glowshiftdirect.com/Tinte...ter-Gauge.aspx
I am also installing a voltmeter with it, and I am just wondering if I can attach the wires from the voltmeter to the wires on the tachometer. For example, once I install the yellow 12v Constant source wire from the tachometer, can I splice the yellow 12v constant source wire from the voltmeter with it?
This is the voltmeter:
http://www.glowshiftdirect.com/tinte...olt-gauge.aspx
Thank-you for looking at my thread, any advice on this matter will help me out greatly!
Re: 96 Honda civic tachometer questions
Also, for those of you who are going to tell me "Those gauges will look stupid sitting on your dash", I am using this bezel, so don't worry, they will look fine
http://www.glowshiftdirect.com/96-00...e-cluster.aspx
I will post pics when all the wiring is finished up!
purple98ek
06-06-2005 07:57 PM
