92 civic dash lights not working
Just picked up a 92 civic and the dash climate control and parking lights dont comeon. Can anyone help me please. Ive checked the fuse 19
Re: 92 civic dash lights not working
Ok ill check the switch and ive checked and there is no power. Does any one know were the ground is cause i think that might be the problem.
GDD Member
Get an ohm meter and put one lead on the wire that should be ground and the other lead on ground. If there's continuity, it'll be 0 ohms, if there's a dirty connection, the ohms will read a number, but if there's no continuity, the meter won't change at all.
Ok so found out the is a good ground its the power im gettinng no power any body know what could cause there to be no power the fuse is good how bout the switch how could i test that? Also my parking lights are not working front and back.
try your parking light fuse or even your brake light fuse i think it is my last car lost dash lights and it ended up being ran off a different fuse then the cluster one
osseau
09-07-2017 08:07 AM
