No heat in my 99 d16y8 please help
Old 10-03-2012, 08:40 PM
maznkid's Avatar
Default No heat in my 99 d16y8 please help
Ever since i bought my car completely stock about a year ago it had no heat. I didnt drive it very much last winter so it didnt bother me. Now its my only car and the heat still does not work. I have tried everything i knew could be the problem, i changed out the thermostat, flushed out the heater core, did an entire coolant system flush, coolant is topped off, but still have no idea whats wrong. Has anyone else had this problem? It has a turbo in it now but it didnt work before that so i know that didnt do anything to it. Thank you for your help.
Old 10-03-2012, 09:09 PM
furious94ls's Avatar
Default Re: No heat in my 99 d16y8 please help
Make sure the lever is connected under the dash.
Old 10-03-2012, 09:12 PM
Ridin Dirty in Cali
dirty19's Avatar
Yep I looked under my dash yesterday and found the cable disconnected.
Nothing worse than freezing in your car.
Old 10-03-2012, 09:15 PM
maznkid's Avatar
Which lever or cable are you guys talking about?
Old 10-03-2012, 09:19 PM
Ridin Dirty in Cali
dirty19's Avatar
The enviromental controls .... behind it will be a metal cable wrapped in plastic that leads to your heater core...
make sure its connected
Old 10-03-2012, 11:18 PM
d15bvtechatch's Avatar
there is a steel cable under your radio inside the car that is could be disconnected.
also, the cable in the engine bay mounted in the middle of the firewall
Old 10-04-2012, 06:12 AM
sde780's Avatar
Make sure your headgasket isn't the problem, D16 turbo builds tend to have issues with them
Old 10-04-2012, 08:27 AM
maznkid's Avatar
So i went under the dash today and messed around with the levers and switching from hot to cold. When i went to full cold, the lever from your pic above turned all the way to the cold side, but when i went all the way hot, it only moved a few notches, no where close to the full hot. So i pushed the lever with my finger all the way to the hot side and then i got a lot more heat than i had before. Guess the cable just didnt push all the way to the hot. Thank you guys so much! and d15vtech for the pic so i could find it. You guys saved me from the winter lol
Old 10-04-2012, 08:56 AM
Glad to help man. Yeah, it didn't sound like an engine coolant problem. Get that taken care of and you should be goodzo.
Old 10-04-2012, 11:27 AM
youknowme87's Avatar
New thermostat will help too. $7
( o )( o )
09-01-2005 09:03 PM
the0ne
12-20-2004 03:26 PM
94_CRVtec
10-29-2004 02:06 PM
juniordc2
04-29-2004 09:33 PM
JeffS
04-30-2002 09:13 PM
Quick Reply: No heat in my 99 d16y8 please help
