need help with replacing axle
GDD Member
Re: need help with replacing axle
You don't even need to take the tie rod off. Remove the lower ball joint, axle nut, and strut fork; move the entire knuckle assembly out of the way and pull the axle out. I don't even pull the fork off the strut, I just remove the lower bolt and move the fork over the lower control arm.
C_Rock77
08-27-2008 11:19 AM
crx18c1
10
04-17-2007 10:17 PM
