You knew it was gonna happen, but you hoped it wouldnt...
Now I am let down. Went to install springs/shocks...and NONE of the bolts were seized except for ONE... in the middle of the driver side LCA... so, as you know, you need a new LCA. *sigh* And the snow is flying soon..
but this i found strange, EG LCA (cast iron)= $300 CDN, 99 Civic LCA(aluminum?)= $80 CDN... what gives!
Re: You knew it was gonna happen, but you hoped it wouldnt... (RangerDan)
Junkyard? Don't pay that much for an lca. If you're gonna pay that much, go aftermarket.
Re: You knew it was gonna happen, but you hoped it wouldnt... (slow_a$$_eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow_a$$_eg »</TD></TR><TR><TD CLASS="quote">Now I am let down. Went to install springs/shocks...and NONE of the bolts were seized except for ONE... in the middle of the driver side LCA... so, as you know, you need a new LCA. *sigh* And the snow is flying soon..
but this i found strange, EG LCA (cast iron)= $300 CDN, 99 Civic LCA(aluminum?)= $80 CDN... what gives!</TD></TR></TABLE>
yep. the difference isn't aluminum vs. cast iron though. both are cast iron. the $80 lca's have the mounting tab for swaybar endlinks. the $300 lca's don't. either will work, and the $80 lca's make mounting a swaybar hella easier.
however, you can replace _just_ the bushing instead of the whole arm. i would suggest this route, as it will only set you back about $30.
nate
nate
sniperslayer
11
10-08-2004 01:54 PM
spencedogg
05-20-2003 06:14 PM
