Motor year????????????
Re: Motor year???????????? (sporty240)
Look on the head, right above the header and under the valve cover, youll see some markings and itll be there. Theres a picture floating around and ill see if i could get that. Next time search.'
Edit: heres the pic, and the thread below
https://honda-tech.com/zerothread?id=548683
Search is your friend.
Re: (sporty240)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporty240 »</TD></TR><TR><TD CLASS="quote">^
ye i'd also like to know that </TD></TR></TABLE>
Block is easy. Look at the number under the engine type stamp... Example, the one under the "B16A1" stamp... The first digit tells the year. If its a B18C and has a "2XXXXXXX" number stamped on it, its a 1995 engine. Why? Becuase production began in 1994, 2 indicates second year production. See what I mean?
Re: Motor year???????????? (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Look on the head, right above the header and under the valve cover, youll see some markings and itll be there. Theres a picture floating around and ill see if i could get that. Next time search.'
Search is your friend.</TD></TR></TABLE>
so this is a 96?
so this is a 96?
Re: Motor year???????????? (wizzards581)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wizzards581 »</TD></TR><TR><TD CLASS="quote">
so this is a 96?</TD></TR></TABLE>
96 GSR head, yes.
96 GSR head, yes.
Re: Motor year???????????? (Hybrid93Eg)
good thang... i need to check mines.. mine is sitting outside.. gettin ready to drop in.. but have problems... opposite wiring ... due to jdm motor...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wizzards581 »</TD></TR><TR><TD CLASS="quote">good thang... i need to check mines.. mine is sitting outside.. gettin ready to drop in.. but have problems... opposite wiring ... due to jdm motor... </TD></TR></TABLE>
Hmm. The JDM swap I did into a gen 2 teg, the wiring was all correct. Didn't require anything special.
Re: Motor year???????????? (HybridRacer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridRacer »</TD></TR><TR><TD CLASS="quote"> eh....vin number on block....got a pic of it....i know its above the stamp.... </TD></TR></TABLE>
huh?
huh?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg »</TD></TR><TR><TD CLASS="quote">
huh?</TD></TR></TABLE>
theres a vin# on the block...i know its on the top of the stamp..got pics.....
edit: nm
edit: nm
edit: nm</TD></TR></TABLE>
The VIN number is on the newer engines. Seems 96 and up they started adding these tags. The VIN isn't near the stamp though. Its on the bottom of the block just above the oil pan.
The VIN number is on the newer engines. Seems 96 and up they started adding these tags. The VIN isn't near the stamp though. Its on the bottom of the block just above the oil pan.</TD></TR></TABLE>
0o thanks
0o thanks
Re: (Hybrid93Eg)
Block is easy. Look at the number under the engine type stamp... Example, the one under the "B16A1" stamp... The first digit tells the year. If its a B18C and has a "2XXXXXXX" number stamped on it, its a 1995 engine. Why? Becuase production began in 1994, 2 indicates second year production. See what I mean?</TD></TR></TABLE>
thanks
thanks
munkyboy111
04-11-2007 05:07 PM
Inisharu D
06-15-2004 04:22 PM
ChrisDaun
24
05-30-2003 08:27 AM
