can i drill a hole in bottum of headlight to reduce water inside?
just an idea i had. i have halo's so i couldn't take them off to blowdry it out or i'd have to rewire everything. would a small hole in the bottum get the water out?
Re: can i drill a hole in bottum of headlight to reduce water inside? (civic-si-2000)
that would work. but you might get dead bugs inside there. you could just reseal the headlights.
Re: can i drill a hole in bottum of headlight to reduce water inside? (sohcvtec1995)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 »</TD></TR><TR><TD CLASS="quote">..you could just reseal the headlights.</TD></TR></TABLE>
cure the problem, not the symptom.
Risky Business
Re: can i drill a hole in bottum of headlight to reduce water inside? (Turbo E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E »</TD></TR><TR><TD CLASS="quote">
cure the problem, not the symptom. </TD></TR></TABLE>
Yep, and you may end up with condensation even if you drill a hole. Fix it the right way.
