d15b zc!! HELP! interchangable stuff? what are the benefits!
ive been hearing about using the d16y8 down pipe on my motor ( d15b zc sohc vtec) . . .. can anyone explain what this helps with and the approx. gains it gives
I also heard that switching the head to a y8 gives higher compression or is my d15b head suitable? just wanted to know a lil more about some of this swapping parts, etc .. .. .. . . . . thanks
d15b vtec motors use a z6 head with a bottom end that is similar to a vx... if you want to beef it up change the rods to either vx or z6. change the intake manifold to either y8 or skunk2/edlbrock. use a header of your preference
Re: d15b zc!! HELP! interchangable stuff? what are the benefits! (HHB 2185)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HHB 2185 »</TD></TR><TR><TD CLASS="quote">ive been hearing about using the d16y8 down pipe on my motor ( d15b zc sohc vtec) . . .. can anyone explain what this helps with and the approx. gains it gives
its basically a 4-2-1 header
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HHB 2185 »</TD></TR><TR><TD CLASS="quote">I also heard that switching the head to a y8 gives higher compression or is my d15b head suitable? just wanted to know a lil more about some of this swapping parts, etc .. .. .. . . . . thanks</TD></TR></TABLE>
go with the Z6 head, its an easier swap
1kleenef
08-04-2008 07:04 PM
JapJunkie
14
07-26-2004 11:42 PM
