Front Sway Bar Installed
Wassup guys, today i finally put my Suspension Techniques front sway bar in my 92 hatch. Everything went well with no problems and the car handles alot better.
Only one draw back, my sway bar rubs against my exhaust when i go over a bump or downshift or anything of that nature. Is there something i can do to prevent this from occuring again?
Thanks, John
Thanks, John
Re: Front Sway Bar Installed (nY's FiNeSt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nY's FiNeSt »</TD></TR><TR><TD CLASS="quote">
Thanks, John</TD></TR></TABLE>
Either get an OEM swaybar or get some exhaust work done.
not really. they hit eachother. one of them has to move.
Re: Front Sway Bar Installed (tonyXcom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonyXcom »</TD></TR><TR><TD CLASS="quote">not really. they hit eachother. one of them has to move.</TD></TR></TABLE>
yup
yup
Unceasing Measure
Re: Front Sway Bar Installed (Pho Real)
By handles better do you mean reacts to steering input better but understeers about twice as bad? Yeah, that's what I thought you said.
geezz..this iso simple. what kind of miricle answer are you looking for?
you have 2 things that are hitting eachother.
One or both of them has to move.
Either move the swaybar or move the cat.
Cant move then swaybar then move the cat.
Cant move the cat then move the swaybar.
Cant move either then remove swaybar. Problem solved.
Cant move either then remove the cat. Problem solved.
sorry, i was thinking maybe the cat could be pushed in just enough to clear the sway bar or maybe after a while of rubbing it'd bend on it's own
yeah, thats why I said at the very beginning..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonyxcom »</TD></TR><TR><TD CLASS="quote">Either get an OEM swaybar or get some exhaust work done.</TD></TR></TABLE>
Unceasing Measure
Take the front swaybar off. It's hurting your overall handling anyhow, whether you choose to accept that fact or not .
Crisper steering response, yes.
Perhaps better launches, maybe.
Better cornering, no.
More understeer at the limit and an earlier limit imposed, yes.
Re: Front Sway Bar Installed (Archidictus)
LOL. Nobody ever uses front swaybars huh?
Matched with a good rear swaybar, you can take away any understeer the front gives you.
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonyXcom »</TD></TR><TR><TD CLASS="quote">LOL. Nobody ever uses front swaybars huh?
I didn't read anything about a larger (or even an existing) front swaybar. Obviously you can offset the negative effects of a front swaybar on a Honda with the appropriate rear counterpart, but you cannot deny anything I've said in the event that it's the only suspension strengthening he's done.
unless you have some extremely stiff springs, you want a front sway. If the understeer is too much, then get a smaller front sway or a bigger rear bar.
Swaybars basically do two things: they decrease roll while cornering, and they decrease grip while cornering.
You can offset understeer with a bigger rear swaybar, but you're simply decreasing overall grip in the process.
Front swaybars induce understeer. Rear swaybars induce oversteer. This is why it's popular to run EG hatches in autocross with a big rear swaybar and no front bar. The car tends toward oversteer while not sacrificing grip.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">By handles better do you mean reacts to steering input better but understeers about twice as bad? Yeah, that's what I thought you said.</TD></TR></TABLE>
you speak the truth. worst mod ever.
i rock Sustec pro SS coilovers and NO swaybars. It rules. incredible grip in all corners and perfectly tail happy for cones and street
I didn't read anything about a larger (or even an existing) front swaybar. Obviously you can offset the negative effects of a front swaybar on a Honda with the appropriate rear counterpart, but you cannot deny anything I've said in the event that it's the only suspension strengthening he's done.</TD></TR></TABLE>
Correct, but dont give other readers the impression that front swaybars are the devil, because they aren't.
Last time I checked, the ITR came with a front swaybar and its arguably one of the best handling fwd cars in the world. The CTR has a rather large front swaybar at 26mm and its handling is near, if not identical to the ITR.
Also, lets not recommend to your average driver to disconnect or remove his front swaybar and leave just the rear. As soon as they let off the gas on a turn, they are more then likely gonna oversteer themselves out of control.
Re: Front Sway Bar Installed (kommon_sense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kommon_sense »</TD></TR><TR><TD CLASS="quote">unless you have some extremely stiff springs, you want a front sway. If the understeer is too much, then get a smaller front sway or a bigger rear bar.</TD></TR></TABLE>
yeah i have really stiff springs, i don't really feel any understeer, that's why i'm kinda scratchin my head
If you have really stiff springs, then your sway bar isn't doing much. Think about it, the main purpose of the sway bar is to reduce chassis roll. Chassis roll basically occurs when one side of the suspension is compressing while the other is extending. Stiffer springs won't compress as much and keep the chassis from rolling as much (if at all).
Guest
Posts: n/a
I'm getting ready to install my agx's and teins s-tech and was looking to put swaybars on my dx hatch but after reading this it makes me unsure to buy a whole front and rear kit or just buy a rear bar or run nothing at all. Help! Should I or shouldn't I buy a whole kit or just run nothing?
OG triple OG
Re: Front Sway Bar Installed (egizzle6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egizzle6 »</TD></TR><TR><TD CLASS="quote">If I go OEM should I stick with just the si/ex or get a ITR swaybar?</TD></TR></TABLE>
yep cant go wrong with oem , ive got a jdm itr rear sway on the back and no sway in the front , hard cornering when i let off the gas it loves to oversteer , but i like it and if your used to it , its not a problem at all . im still debating on whether or not to get a ctr front sway , havent decited yet.
Re: Front Sway Bar Installed (TURSpoonEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURSpoonEK »</TD></TR><TR><TD CLASS="quote">
yep cant go wrong with oem , ive got a jdm itr rear sway on the back and no sway in the front , hard cornering when i let off the gas it loves to oversteer , but i like it and if your used to it , its not a problem at all . im still debating on whether or not to get a ctr front sway , havent decited yet.</TD></TR></TABLE>
if only ctr sways fit on an eg
